Unexplained file size increase
hi.
when I try to save an DWG file on my PC, I get the following error: "Unexplained file size increase.Retry?"
I click Retry. Tha same error.
anyone have had similar issue?
Your advice is greatly appreciated.
imadHabash
Hi and Welcome to AutoCAD Forum,
i suggest to do the follow and see if any differences happened :
  • Type -PURGE ==> "R" for Regapps (registered applications), then Enter.
  • "N" when asked to verify each name to be purged, then Enter.
  • Type PURGE at the command line. With all checkboxes checked on, click Purge All.
  • Audit and fix any errors:
    • Type AUDIT at the command line.
    • "Y" for Yes to fix any errors, then Enter.
Now save your drawing and see if it's fixed. if NOT and from blank new drawing type RECOVER your CAD file.
Note : if all of previous steps didn't work please try to follow this LINK for more help.
Good Luck..
Imad Habash
hi @Anonymous
i think you have to compress your file to save it.
By using commands like AUDIT,PURGE,DXF.
https://www.youtube.com/watch?v=XEHTzOZuXmM
this link will help you to compress your file.
Thank you.
Many thanks for the help. I shall try
Alfred.NESWADBA
do you use AutoCAD or SolidWorks? Because imho that message is only known for Solidworks.
Can you create a screenshot from that message please and show that to us?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
m0andino,
In AutoCAD there is a tick box in the purge dialogue to purge orphaned data, make sure this is ticked on.
Take a look at this link to see if it may be related: http://www.dwg.repair/
