Unexpected behavior
Unexpected behavior
builder7772001
Message 1 of 8
Unexpected behavior
builder7772001
When I save my drawing, it goes to the top view. Also, when I start the line command and click to start the line it will do the same procedure - the view goes back to the top view. Not sure if I changed a system variable or not.
Looking for advice.
Replies (7)
Message 2 of 8
jrreid
Not sure if this will help but...
Close your drawing.
Type Recover inside AutoCAD and then open the Drawing.
See if there are any errors in the drawing to cause this issue.
Hope this helps.
JRR.
Message 3 of 8
pendean
Community Legend
Community Legend
UCSFOLLOW is set to what?
Does this happen with ALL of your files, or just this one?
If ALL files do this, restart your PC yet to see if that fixes it, unless you have a new add-on or startup helping out be resetting something.
Or you can post the problem file here for others to review.
Message 4 of 8
builder7772001
Thank you for your response. USCFOLLOW is set 0.
What does this command do?
Message 5 of 8
builder7772001
Not sure where to type recover inside AutoCAD. On the start page or in a
new drawing?
Thank you for your time.
Doug
Message 6 of 8
builder7772001
UCSFOLLOW is set to zero.
This doesn't seem to affect other drawings.
Message 7 of 8
pendean
Community Legend
Community Legend
RECOVER is either typed a the commandline, or accessed from the big red A at the top left corner of your AutoCAD window: it is also explained in HELP in the program.
Message 8 of 8
builder7772001
Ok thank you. I just copied the whole drawing to a new file and replace the existing one. The problem is not happening in the new file.
Thanks again
