AutoCAD Forum
Undo block edit crashes AutoCAD
1 REPLY 1
martin.hong
148 Views, 1 Reply
Hi all,
For some reason everytime I undo in a drawing and it involves undo-ing a block edit, it would just freeze and not respond... this happens across different drawings and I am not sure why this is happening. Has anyone experienced something similar?
Tags (2)
1 REPLY 1
pendean
in reply to: martin.hong
Not enough information, sorry.
Share screenshots of your AutoCAD's ABOUT command pop-up and confirm your OS plus where do you store your DWG files and how often you manually save using QSAVE command.
AutoCAD Inside the Factory
