Anuncios
UNDERLINE MULTIPLE MTEXT ENTITIES
cleftwich
cleftwich
Does anyone know how to underline multiple mtext entities at one time through a lisp or other means. Currently I use an archaic and time consuming way of completing this task, any help would be appreciated greatly,
Charles
0 Me gusta
Responder
Soluciones aceptadas (2)
7.778 Vistas
23 Respuestas
Respuestas (23)
sam_underdown
Observer
Observer
Please see the above screen snip
the underline goes under all characters, so i am not sure what is causing the issue, lisp routines are new to me so apologies if i am asking silly questions
the command still fails and returns the following
Command: (cdr(assoc1(entget(car(entsel)))))
Select object: ; error: no function definition: ASSOC1
i have attached the cad file i am having trouble with so you can take a look, perhaps i am missing something obvious?
0 Me gusta
Kent1Cooper
Your pasting-in of the code snippet lost all spaces.  Some of them don't matter, but the one between assoc and 1 is necessary.
But anyway, those Mtexts somehow do the underlining in a different way than currently, without the { } "wrapper" around formatted parts.  A sample instance returns:
"\\L+39.600"
So those don't meet the filter criteria for the content, which is why UUMT's object selection didn't "see" them.  But sure enough, when edited to remove the +, it automatically gets "updated" to the current practice:
"{\\L39.600}"
Even simply double-clicking on one to get into Mtext-editing, and then clicking away to get out of it, without changing anything, causes the same update of the formatting code, so it's not about the + per se.
Maybe that no-{} way comes from an older version, or something brought in from other software, or....
But that "option" in the way the underlining is coded can be accounted for [minimally tested]:
(defun C:UUMT (/ ss n edata txt); = Un-Underline MText(s)
  ;; to remove underlining from Mtext whose ENTIRE content is underlined
  (if (setq ss (ssget "_:L" '((0 . "MTEXT") (1 . "{\\L*,\\L*"))))
    (repeat (setq n (sslength ss)); then
      (setq
        edata (entget (ssname ss (setq n (1- n))))
        txt (cdr (assoc 1 edata))
      ); setq
      (entmod
        (subst
          (cons 1
            (if (= (substr txt 1 1) "{")
              (substr txt 4 (- (strlen txt) 4))
              (substr txt 3)
            ); if
          ); cons
          (assoc 1 edata)
          edata
        ); subst
      ); entmod
    ); repeat
  ); if
  (princ)
Kent Cooper, AIA
sam_underdown
Observer
Observer
@Kent1Cooper it works perfectly now, thank you so much for your help, it's appreciated!
0 Me gusta
Kent1Cooper
How about this?  A universal one, all in one command for not only Text and Mtext but also MultiLeaders and text-overridden Dimensions [again -- entire content underlined for all but plain Text].  Lightly tested.
;| UnUnderlineText.lsp [command name: UUT]
To remove all underlining from plain Text objects, and from Mtext and MultiLeader
  and text-overridden Dimension objects whose ENTIRE content is underlined.
Not for Mtext/MultiLeaders with long-enough text to go into multiple text-content
  entries [DXF codes 3 and 1] in entity data.
Kent Cooper, 19 July 2023
(defun C:UUT (/ ss n edata etype txtdxf txt); = Un-Underline Text(s)
  (if
    (setq ss
      (ssget "_:L"
        '( ; filter list
          (-4 . "<OR")
            (-4 . "<AND") (0 . "TEXT") (1 . "*%%U*") (-4 . "AND>")
            (-4 . "<AND") (0 . "MTEXT,DIMENSION") (1 . "{\\L*,\\L*") (-4 . "AND>")
            (-4 . "<AND") (0 . "MULTILEADER") (304 . "{\\L*,\\L*") (-4 . "AND>")
          (-4 . "OR>")
        ); filter list
      ); ssget
    ); setq
      (setq
        etype (substr (cdr (assoc 0 edata)) 1 2); "TE" / "MT" / "MU" / "DI"
        txtdxf (if (= etype "MU") 304 1)
        txt (cdr (assoc txtdxf edata))
      ); setq
      (if (= etype "TE")
        (while (wcmatch txt "*%%U*") ; then [Text]
          (setq txt (vl-string-subst "" "%%U" txt))
        ); while
        (setq txt ; else [Mtext/MultiLeader/Dimension]
            (substr txt 3)
          ); if
        ); setq
      ); if
      (entmod (subst (cons txtdxf txt) (assoc txtdxf edata) edata))
    ); repeat
  ); if
  (princ)
); defun
Kent Cooper, AIA
0 Me gusta
