Unbold text appearing bold
No aplicable
All I want is normal text but Autocad decides my text must shout from the top of the roof their value. I've tried all the stuff like - match properties, no ctb, text editing, by layer and even retyping. Please help me get out of this problem.
0 Me gusta
Responder
5.110 Vistas
11 Respuestas
Respuestas (11)
imadHabash
Hi and Welcome to AutoCAD Forum,
please attache your CAD file here and mark the text related ?
Imad Habash
0 Me gusta
Kent1Cooper
In case this might be your issue, I have found that .TTF fonts, when used at a width factor other than 1, often look bolder on-screen, but don't plot that way.
If that's not the cause, I agree that a sample and/or some screenshots would help.  Are you talking about .SHX or .TTF fonts, or both?  Is it happening in plain Text, or Mtext, or Attributes, or Dimension text, or all of them?  In Mtext, is there internal formatting?  Etc.
Kent Cooper, AIA
pendean
Community Legend
Community Legend
Is your TTF font Mtext at a Z height other than 0.00?
No aplicable
How to check z height....I don't see it in properties
0 Me gusta
No aplicable
Attaching screencast here ...I dont see  the said position
0 Me gusta
No aplicable
As advised in a later suggestion below, I've changed the z position of all the texts to zero because of which they appear normal on screen but while printing, they still are bold. Sorry for the bad print, the paper got jam. Printed_cad_file[2].jpgbold_text[1].JPG
0 Me gusta
Kent1Cooper
But I would expect that to effect [as does non-1 width factor] what it looks like on-screen, but not to make a difference in plotted weight.
Are those parts really of the same color as the ones that plot lighter?  Could they be some dark grey or the darkest end of the range of some other color, that looks black on-screen, but isn't really, and is of a color with a different plotting weight?  That could only be the cause if it's in a .SHX font, but it looks more like a .TTF font in your images, so that may not explain it.
Kent Cooper, AIA
0 Me gusta
No aplicable
Yes, it is .TTF font everwhere! The color is same everywhere. The plot style in 'none'.
0 Me gusta
No aplicable
In my case i checked everything (z levels, layer manager, lineweights, text styles ) and everything was ok. I tried to navigate in 3d from the cube (tab view-> view cube) and when i pressed top view in the cube the text was fixed. It seems it was a matter of appearance of the text by autocad and there wasn't any real problem. Hope it helps.
0 Me gusta
No aplicable
TRY USING COMMAND "LWDISPLAY" AND TURN IT OFF
pendean
Community Legend
Community Legend
@Anonymous
1) you are replying to a 3-year old post.
2) LWDISPLAY has no effect on TTF fonts if you id not know before today. The issue is their text is not a Z=0 as noted in message #8 above.
0 Me gusta
