Unblocking a block
Unblocking a block
Unblocking a block
I have a call center floor plan and need to reconfigure several cubicles however, who ever created the blocks did not allow exploding the blocks. how do I unblock a blocked floor plan.
beyoungjr
Can you edit the block used?  Select the block and right click to choose block editor.  If you must keep the originals then just save the block as a new name before leaving the editor.  Then insert the new block where you need it.
Blaine
Blaine Young
Senior Engineering Technician, US Army
rkmcswain
GrantsPirate
Start the BLOCK command, pick the block name in the list, add a check mark for Allow Exploding, pick OK, pick Redefine Block.  You are done.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Kent1Cooper
Or, so you don't need to know the specific Block name for each one to pick it from a list, double-click on an insertion of a Block to call up the Block editor, accept the offered Block name as the one to edit, and in the Properties palette, change the "Allow exploding" slot [toward the bottom] to say Yes instead of No, and Close the Block Editor.
Kent Cooper, AIA
