Anuncios
Unable to save dwg with pdf on it
semraozturk
semraozturk
Hello
I somehow can not save my dwg file while there is pdf or jpg on it. The warning window says there are some formats on this drawing which can not be saved. But this is something I constantly do and this is the first time I came across to this warning. What might be wrong? Thank you in advance!
0 Me gusta
Responder
Soluciones aceptadas (1)
1.421 Vistas
4 Respuestas
Respuestas (4)
john.vellek
HI @semraozturk,
Which version of AutoCAD are you using and in which operating system version?
Can you give me the exact error message?  If you are willing to share the pdf/jpg files along with the drawing I would like to try to duplicate on my side.
John Vellek
0 Me gusta
semraozturk
I am using Autocad 2017 and 64-bit version. The drawing which I am working on now is not important but it is a feature I often use so it would be great for my future projects. So I am just sending the warning window as an attachment but unfortunately it is in German. I hope it still can you give the idea.
john.vellek has embedded your image(s) for clarity
0 Me gusta
john.vellek
HI @semraozturk,
The message (I don't speak German) appears to indicate that there is proxy information in your drawing (not PDF related).  To access the Proxy information you will need to install the appropriate Object Enabler. Then, use -EXPORTTOAUTOCAD if you want to convert this geometry to plain AutoCAD entities.
John Vellek
0 Me gusta
semraozturk
Solución aceptada
I think it was one time thing. I did not change anything but it was all okay the next day. But if I encounter the same problem again I will try the method you have suggested. Thank you for your help.
0 Me gusta
