Unable to revolve the selected object
Hi all,
I draw a profil to create a revolve solid around Y axis (file enclosed).
The profil is closed (coincident constraints between the different elements).
The created object from : Solid > revolve is actually a surface model (error message : Unable to revolve 1 selected object, but which one???). I used SOLID > revolve and not SURFACE > model.
Then I did a test with a basic shape : a rectangle.
From Home > draw > rectangle, the obtained shape revolve (around one of the retangle edge) is a solid (from Solid > revolve). However, if a create a rectangle with 4 segments I get a surface model (from Solid > revolve) ...
How is this possible?
Could someone help me to create a SOLID from my profil instead of a surface model?
Thanks a lot in advance for the help. 🙂
Benjamin.
imadHabash
I suggest to change your 2D shape to polyline by (bpoly) command then you will get the result that you want from Revolve command.
Imad Habash
That's kind of a funky drawing there. Whenever I tried to copy geometry it seemed like nothing happened. In fact when I tried some commands it seems they were disabled.
But I did get it to revolve into a solid. First I had to remove the constraints, then I saved, opened a different drawing and inserted the revolution.dwg, explode, created a region, and revolved the region.
Weird, I just opened the drawing again and now I can work with it
Hi man
Pedit,,Region..and revolve goes!
thank you very much for your help!
Benjamin
