Unable to print Text having Plus/Minus (±) symbol when converting cad to pdf
I'm using AutoCAD 2010 for preparing architectural drawings, have to mention levels in elevation & plans. But after converting CAD file to pdf, level showing zero level (± 0'-0'') has changed to other text.  How to get the same level after converting CAD drawing to PDF. Please suggest...................
alex101000
What font is used? Can you upload this font for the sample? What is the output method in PDF you use?
Alfred.NESWADBA
have you tried to change the PDF-options and check "Capture All"?
Also the question "which font" is not answered yet ...
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
THANK YOU VERY MUCH........ IT HAS SOLVED
SORRY COULDN'T UNDERSTAND THE LANGUAGE, YOU SHOWED IN IMAGE, BUT I GOT IT .... WHAT YOU SUGGESTED. THAT'S WHY I ACCEPTED YOUR SOLUTION
