Unable to get overlined / underlined / strikethrough MText, Dimension text, Multileader text
No aplicable
Dear community,
I know these special properties of the plain text in AutoCAD:
- overstep the text
- underestimate the text
- striketrough the text
e.g. combined:
How can I aply these text possibilities to MText, dimension text or multileader text?
Many thanks in advance and have a nice weekend
0 Me gusta
Responder
Soluciones aceptadas (2)
859 Vistas
3 Respuestas
Respuestas (3)
Alfred.NESWADBA
Solución aceptada
Manually ... select the part of the text you want to assign the property and click the corresponding button inside the MTEXT-ribbon:
If you want to know how this is internally saved, then create an MTEXT with the attributes you want and look to the property window, property "Contents":
Does this help?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
Solución aceptada
Click on below image to see how you can get them ... you can get that Toolbar if you right click on the mtext space then go down to Editor Settings then Show Toolbar    . :cara_con_una_leve_sonrisa:
Imad Habash
No aplicable
Many thanks,
these operators + @Alfred.NESWADBA  + @imadHabash helped me :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
\L
\O
\K
Have a nice weekend
