Unable to form a union of two 3D objects!!
bencharlton5C8EZ
Message 1 of 8
bencharlton5C8EZ
Hi All
Can anyone give me any pointers of why I'm struggling to form a union of these 2 parts please?
Replies (7)
Message 2 of 8
imadHabash
@bencharlton5C8EZ
You have an incomplete intersection for both solid objects. The bodies might only be touching at a single edge or point rather than passing through each other. The idea is to Move one body slightly to ensure a proper intersection to finally get a successfully union result.
Click on below image for more clarification...
Imad Habash
Message 3 of 8
bencharlton5C8EZ
Thanks Imad
I have watched the video but I am not quite following.  Have you simply moved one part relative to the other and it then allowed a union?  I dont really understand as the parted clearly overlap considerably.
Message 4 of 8
imadHabash
Yes... The idea is to Move one body slightly to ensure a proper intersection.
Imad Habash
Message 5 of 8
TheCADnoob
there is a lot of cleanup that would need to happen. For instance this is from a what i believe is meant to be a flat surface
CADnoob
Message 6 of 8
bencharlton5C8EZ
But I believe them to be correctly aligned with each other as it is - if I move one then they wont be any more?  Apologies if I misunderstand.
Message 7 of 8
bencharlton5C8EZ
Where abouts is that please?
I'm fairly new to this (as you can probably tell!) and trying to produce this (to me) complex shape has tested me a little!
Message 8 of 8
imadHabash
The idea is to make a little bit more intersection between the two parts (overlap), So you can successfully complete Union command.
Imad Habash
