Unable to fillet solid edge
I designed a simple solid (a table leg) and I was able to fillet two of the four long edges with a radius 15 mm.
AutoCAD does not allow me to fillet the other two edges regardless of the radius I input. I even tried with 1 mm radius just for testing.
I get error 102026.
Is this a bug or I am doing something wrong? In the picture you will see that two of the edges are filleted, I need to fillet the other two edges all along the solid. I have attached the dgw. file.
Thanks for the support,
Felice
parkr4st
attached the dwg.  it works no problem.  FILLETEDGE and select 9 edges on each of the corners.
dave
john.vellek
Hi @Anonymous,
Unlike @parkr4st, I also had some problems getting the Fillet Edge to work on your model.  I had been selecting each portion of the edge individually and received a few different error messages.
However, when I tried again, I used the Chain edge and that seemed to work perfectly.
I have attached a quick video showing this process. I did this exercise in AutoCAD 2016. Which version of AutoCAD are you using?
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @parkr4st's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Thank you.
The procedure you suggested is working also for me.
Thanks for the hint,
Felice
