unable to export PDF as realistic Visual style, i can only export as wireframe
ak_29_mech
Observer Observer
Message 1 of 8
ak_29_mech
Observer
Observer
I am trying to export PDF as a 3D realistic but when i do that, i get an empty PDF, without layer information. Same happens when i change visual style to "Shaded" or "shaded with edges".
But when i change visual style to wireframe it shows everything on the PDF with the layers information.
Replies (7)
Message 2 of 8
paullimapa
Is there a reason you don't want to use the PLOT command & select DWG to PDF.pc3 to generate the PDF?
Paul Li
IT Specialist
@The Office
Message 3 of 8
ak_29_mech
Observer
Observer
That's working, same as PUBLISH command, just wondering why exportPDF suddenly doesn't work the same
Message 4 of 8
paullimapa
I don’t recall Export pdf ever giving you shaded images
Paul Li
IT Specialist
@The Office
Message 5 of 8
pendean
Community Legend
Community Legend
Suddenly? As in it used to work for you? Perhaps you skipped a step like
Or was that just a turn-of-phrase?
Message 6 of 8
ak_29_mech
Observer
Observer
I tried that, didn't work.
i didn't skip any steps, i just recently (2 months ago) purchased ACAD 2023 and exportpdf worked just fine at the beginning  but now it changed
Message 7 of 8
pendean
Community Legend
Community Legend
Test and confirm, then share a DWG file of an earlier example that worked, and your current DWG file that does not work: shouldn't take anyone around here long to help you figure it out if you don't see it right away.
TIA
Message 8 of 8
leeminardi
See if SAVEIMG yields something you can use.
lee.minardi
