Hello All,
In my current task I need to extract all Dimensions and redraw as it is.
To do so I am extracted all Dimensions DXF code in excel file and save it and read excel cell with function "read" and draw it using "entmake ".
The output is same but for vertical dimension the text direction is change. see attached picture.
To find any dissimilarity in new and old dimension I checked all property but they all are same, checked DXF code this also same , and checked vlax property they also same.
I can't find any dissimilarity in those dimension but still it's look different.
Herewith attached similar code you may check it.
(defun removeEntity (lst / returnlst) (setq returnlst nil) (foreach val lst (if (/= (type (cdr val)) 'ENAME) (setq returnlst (append returnlst (list val)) ) ) ) returnlst ) (defun c:redim () (setq sel1 (ssget "x" '((0 . "DIMENSION"))) lstColl nil ) (if sel1 (progn (repeat (setq n (sslength sel1)) (setq lstColl (append lstColl (list (vl-prin1-to-string (removeEntity (entget (ssname sel1 (setq n (1- n) )))) ) ) ) ) ) (if sel1 (command "_.Erase" sel1 "")) (if lstColl (foreach val lstColl (entmake (read val)) ) ) ) ) )
'New' looks readable , are you saying you need as 'Original' ?
Have you tried reversing the selection order as you place the dimension?
It seems to be a form of a mirror happening.
-Tim C.
