Unable to detach xref.
JeffLMoran
Message 1 of 12
JeffLMoran
Why do I get the message "Unable to detach xref. Multiple references detected" instead of just detaching the xref files? I know there are multiple references. I want them all removed! Just detach all!
Replies (11)
Message 2 of 12
imadHabash
>> I want them all removed! Just detach all! <<
i suggest to try from command line . also Purging your drawing will prevent any similar problems.
-XREF
D
Command: -XREF
Enter an option [?/Bind/Detach/Path/pathType/Unload/Reload/Overlay/Attach] <Attach>: d
Enter xref name(s) to detach: *
Imad Habash
Message 3 of 12
JeffLMoran
Thanks for your response, imadHabash, but that didn't work.
I have a file with a title block attached to multiple sheet layouts. Unless I go into each layout and delete the reference or just erase all sheet layout that have the title block ref, I can not detach. I'm wondering if there is a way to just detach without having to do that.
I KNOW I want them ALL removed!!!! Just detach them. It's frustrating!
Thanks Again
Jeff
Message 4 of 12
cadffm
Thats not possible, Acad can detach a XRef only if all references are unnested in Modelspace  (external references = objects which are display the Xref).
[editSTART]or without any references[editEND]
You have references in Layout(s) or nested in Blocks. Clear that situation and you can detach the Xref.
Sebastian
Message 5 of 12
imadHabash
you know what ... some times i stuck in what you're suffering from , to discover later on that when i close the file and reopen it again all xrefs are gone !!!
would you try it ?
Imad Habash
Message 6 of 12
rkmcswain
Good question. Never made sense.
Just do it!
R.K. McSwain     | CADpanacea | on twitter
Message 7 of 12
-FDC-
Nested xrefs! Set them to overlay in your Original file or detach the main xref.
Go to tree view:
And delete the main xref.
Message 8 of 12
cadffm
@-FDC- Thats possible, but JeffLMoran wrote -> "I have a file with a title block attached to multiple sheet layouts."
CADffm - "Acad can detach a XRef only if all references are unnested in Modelspace  or without any references"
So @JeffLMoran have to clear the situation by delete als paperspace references of that XRef,
but Acad have no command to do that in one step, he want(need) a custom-command like that (too) simple example:
(defun c:DelTopLevelBlockReferencesOf (/ ss) ; without Layermanagment
  (if (setq ss (ssget "_:S" '((0 . "INSERT"))))
      (foreach i (ssnamex (ssget "_X" (list'(0 . "INSERT")(assoc 2 (entget(ssname ss 0))))))
    (if (vl-catch-all-error-p(vl-catch-all-apply 'vla-delete (list(vlax-ename->vla-object (cadr i)))))
      (princ (strcat "\nCannot delete Objects on locked Layers (Layout: " (cdr(assoc 410 (entget (cadr i))))")"))
 (princ)
Sebastian
Message 9 of 12
JeffLMoran
CADffm, Thank you!!
I think the lisp is just what I needed. I need to study it a bit, but it worked on the particular file I was working on.
Message 10 of 12
cadffm
But be careful, it works with all non-nested block references on unlocked layers (including frozen layers), not just for externally-dependent ones.
Sebastian
Message 11 of 12
spb_co_il
Just happened to me - turns out it WAS a nested Xref - BUT!  it was somehow nested INSIDE A BLOCK 😮
someone must have accidently selected the Xref with other objects while turning them into a block, and it remained that way.  its a first for me.
Message 12 of 12
Goody1977
If it is the Title blocks that are not detaching. Delete them out of paperspace.
