UCS
UCS
UCS
When I rotating my UCS around the "X, Y or Z" axis, I type UCS, specify X, Y or Z and hit enter, enter and it used to default rotate at 90deg. I must have accidentally hit a button and changed it, because now it rotates at 45deg. How do I get it back to the 90deg. without having to type in 90 each time.
pendean
Community Legend
Community Legend
Watch the commandline, even expand it to be 3-4-5-6 lines tall, there you should see it is defaulting to <45>, you need to type 90 once to make it the default again.
Always watch the commandline, AutoCAD loves to always tell you what is going on.
Unfortunately that doesn't work. I should have been more specific, most commands are typical for autoCAD and CADWorx, but not for this, I am using CADWorx Plant Professional, Autodesk AutoCAD. It doesn't give a default in the command line.
