Two Items Selected, but only One Moves
ShetEE
ShetEE
In my drawing, I click and drag to select two items. I then use the move gizmo to move them. Only one items moves.
These two items are in two layers, but neither layer is locked. I am sure that both are selected. This is very repeatable.  It seems to only happen when I'm zoomed out a bit. After the move, I can zoom in and see that both are still selected. I can then make another move without reselecting anything, and they both move.When I type M for the move command, this issue doesn't seem to exist.
In different words. I click and drag to select item A and item B. I confirm that both are selected. I use the gizmo to move them in x by +10. When I click at the new location, I see only A has moved to X+10. B is left behind at x0, but still selected. I zoom in closer. I use the gizmo on these two items again without making a new selection. I move them in x by another +10. Now A is at x+20 and B is at x+10.
I've attached a screen grab showing during the actual move command, prior to selecting a second point. The two original pieces are on the right with A on bottom, B on top. You can see both are selected. When I use the gizmo to move in X, you see only item B is moving.
If it's important, I am using Autodesk AutoCAD 2019 on Windows 10.
Update:
After reviewing my post and image, I see that the gizmo is doing a stretch and not a move. This might be my issue. Now, can someone explain why it's changing to Stretch when zoomed out?
jayhar
Kindly Short Your Question please.
set PICKADD <2>.
Quit AutoCAD and starting it again.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Kent1Cooper
If by "use the gizmo" you are talking about grip-editing, pick a grip and hit ENTER, and it will go into Move mode, and both will be moved.
Kent Cooper, AIA
ShetEE
Hey, that did it! I thought that the grip was explicitly called the gizmo.
Can you tell me why the zoom level changes which mode it starts in?
ShetEE
I've seen people complain of insufficient information, so I thought a more detailed question would be better.
PICKADD is already set to 2. This should not be the culprit anyway, as I'm selecting both items simultaneously with a selection window. Is that a fair statement?
