So, I'm having trouble understanding exactly how layers are supposed to work when you've got things like block references in the mix.
Here's my situation. I've got a block "Mike's Block" defined with three objects, on layers "A", "B", and "C". I add a reference to "Mike's Block" to my drawing. I put the REFERENCE onto layer "D".
If I turn off layers "A", "B", or "C", then the objects on those layers are hidden, regardless of if they're in a block reference or not. This is what I would expect to happen.
However, if I turn layer "D" off, while the "A", "B", "C" layers are turned on, I expect to see only the block reference go away.
But nothing happens on screen. The reference is still visible.
I see something similar with arrays. If I put the array object into a separate layer, then turn off that layer, the object doesn't go away on screen.
So, is there a way to make it do what I want?
