I’m having trouble rounding-off dimensions. Attached is a sample. I’m working with drawings that were originally created in the mid-90s by drafters who didn’t have (or know how to use) viewports. All of the drawings were scaled down to fit a titleblock in model space, then the dimensions were overwritten to show the “correct” lengths. Now I’m converting them to modern standards and have scaled everything back up and using viewports as needed.
The problem is the dimensioning. With some, the new dimension in paper space shows the correct dimension but with others it shows odd lengths, such as 7.99” instead of 8”. A good example is “Section 4-C” on sheet 2. If I go into to the dimension settings and try to round off at two decimal places, it keeps reverting to four. I tried changing DIMRND but have the same problem with it resetting.
Also, there are some very odd blocks that I can’t edit. I get the message “Cannot REFEDIT anonymous block” – all I want to do is change the color from yellow to black to make it easier to see them on a white background.
What have I missed or what am I doing wrong? Thanks.
