Trying to copy objects out of a drawing that says it contains proxy objects, what to do?
ghunt4MWG6
ghunt4MWG6
I am currently working in standard Autocad 2018. I have a survey basemap file that was sent to me, I believe it was done in Land Desktop but as it was sent it all looks like regular Autocad objects.
I need to copy the basemap objects into another drawing. When I try to copy with a base point it says "Copy to clipboard failed." If I try to WBLOCK it says it can't do it due to proxy objects.
I tried -EXPORTTOAUTOCAD and DWGCONVERT. With -EXPORTTOAUTOCAD it created a new file, but I get the same issues- if I WBLOCK the whole drawing, the basemap objects are missing for some reason. If I try to just WBLOCK the objects I need, I get the proxy object error still. DWGCONVERT didn't seem to do anything useful.
Is there another command I can run to get rid of the proxy objects?
pendean
Community Legend
Community Legend
Share your DWG file here.
ritzofriya
Turn On all layers
unlock all layers
unfreeze all layers
do purge, overkill, audit, then flaten,
then try again. it should work.
ghunt4MWG6
Well I got WBLOCK to work, not sure if the purge/audit/overkill/flatten chain was what fixed it or if I was doing something wrong with with WBLOCK but at any rate I got it copied over. Thank you all
Valentin_CAD
@ghunt4MWG6 ,
Try the suggestions on this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
DPartanen
This is a issue that pops up for me sometimes.
The best solution for me was converting the DWG into a pdf then importing that PDF into my template.
