Trying to convert from dwg to stl
Hi Everyone
I have been on this for a week now i am trying to convert it into an stl file but am unable to do it. I have tried everything but i am still failing. Please help me out.
Hi
Please follow below procedure.
1. Open Dwg file first
2. Click File--> Export (or) Directly Click A Symbol (autocad symbol) and Click Export
3. Choose other format option
Now select Required file type ( in Files of type section )
Then click Save and select object
imadHabash
Hi and Welcome to AutoCAD Forum,
>> I have tried everything but i am still failing. Please help me out. <<
like what ? what commands you used ?
as mentioned ... EXPORT command has the ability for converting dwg files to stl .
Imad Habash
Alfred.NESWADBA
STL needs watertight volumes (3D-Solids or Meshes), your file only contains surfaces and so that geometry can't be used to be exported to an STL file.
When you start command _EXPORT, after you defined the filename, the command asks for selecting objects. With your geometry you see then:
The only 3D-Solid you have is the top object, but even that has a thickness of 0, so not a volume.
You need to convert your object to a 3D-Solid, then run command _EXPORT with that object.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
How cab i turn it into solid
Alfred.NESWADBA
run the _LOFT command again with your splines, but either use the _LOFT command from "SOLID" ribbon or make sure to set the option _MODE to "Solid" at the start of the command.
- alfred -
Alfred NESWADBA
