I have no commandline in my TrueView... how do I get it back? help!
Solved by pendean. Go to Solution.
I lost my command line when moving it and can't get it back. control 9 does nothing
anyideas...very new at this so be easy
thanks
Have you gotten an answer to this? I have the same problem. Although a portion of the command line is on screen, it is the portion you can do nothing with. Help! The tip listed above does not work. The other tips are for Autocad, not Trueview.
The tip does not work for the command line retrieval in Trueview 2014. You can move the Trueview window itself, but the command line window is not anchored to this window at all. No part of the command line window that is visible can be moved. I picked Trueview from the apps. Any other suggestions? Appreciate the help. I suppose I could re-install, but I would lose my customizations, which is some work.
Had same thing happen me..
Try this.
CTRL+9. if this does not work go to top of screen and check top toolbar if menu bar is visible.
If not make it visible.
Then go to tools and you can select it on or off from here
Hope that works as did for me
D
