- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In acad MEP, text written in Stylus BT and other TrueType fonts no longer displays as smooth, but instead is rough and jaggy. I had downloaded acad MEP for a trial and opened a drawing I had made with another acad version. The text problem seemed to have started after I'd experimented with some of acad's settings (Visual Style, and changing the 3D orientation on the Model Space). But in each case I'd reverted to the original settings afterward; and yet the text problem remains. (a graphic attached shows some offending text)
I've seen earlier posts on this problem, from 2008 and 2015, and worked through all their solutions:
- Set Visual Style to 2D Wireframe (but toggling betw. 2D Wireframe and Wireframe appears to make no difference to the quality of text anyway)
- Ensured that when the problem text was selected (text editor), Oblique angle = 0, Tracking = 1.000, and Width factor = 1.000 (they all had these values and had not changed)
- Clicked on the “Top” button of the Viewcube icon to ensure that the view was completely planar.
But nothing has helped, and the only type face that is still smooth is romans, which I'm now using. Is there any way to fix this?
