Troubles with assigning length to the line
m_abdullayeva2
Observer
m_abdullayeva2
Observer
Observer
Hi all,
I am new to CAD and trying to learn the basics through video tutorials. My issue is that when drawing lines I cannot assign length to it. Say that I apply start point, then type the length I need (for example, 2000mm) then click enter but it doesn't do anything and keeps asking me to clarify the end point. I have tried searching online and did all suggestions but it still didn't help. The length type is decimal and my units are millimeters. Tried to turn off ortho mode and it didn't help. I am using AutoCAD 2024 version. Any help would be appreciated. Thank you
0 Me gusta
Responder
Soluciones aceptadas (1)
395 Vistas
4 Respuestas
Respuestas (4)
Patchy
Units, set it to decimal, and skip the mm when entering.
0 Me gusta
cadffm
Start LINE command
pick a startpoint in a blank area.
type in 2000<enter>
and one <enter> more to exit the command.
can you see a point, or nothing?
Sebastian
0 Me gusta
Kent1Cooper
Solución aceptada
The LINE command always "keeps asking me to clarify the end point," asking for the next end point, so you can draw multiple end-to-end contiguous Lines in one command.  Just hit Enter when you're done, even if after drawing only one Line.
As for the "it doesn't do anything" part, could you be Zoomed out so far that the Line is just too tiny to see?  Try this to check whether it did anything:
LINE
{pick a start location}
{aim the cursor in the direction you want to go and type in a length}
{Enter to complete the command}
LIST
Last
{and another Enter to complete selection}
Does it report that the Last object is a Line, and of the desired length [along with all the other information about it]?
Or instead of using LIST after the LINE command, try:
ZOOM
Object
Last
Now can you see it?
Kent Cooper, AIA
0 Me gusta
m_abdullayeva2
Observer
Observer
Thank you so much! Yes, I was apparently zoomed out far.
0 Me gusta
