Anuncios
Trouble with sculpting surfaces
No aplicable
I have AutoCAD 2016 student version installed. I've included a screenshot of the drawing I'm working on. When I try to apply a COINCIDENT or TANGENT constraint to the ARC's right end of the horizontal line, I keep getting a message saying it will over constrain the drawing. I had no problem applying a COINCIDENT constraint to the left end of the ARC as you can see. Is there a solution to this problem? Thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
292 Vistas
3 Respuestas
Respuestas (3)
Alfred.NESWADBA
it's much easier if you upload the dwg-file, we can't test constraints in your screenshot.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
j.palmeL29YX
Solución aceptada
You have too many restrictions in your geometrie. As far I can see it should be possible after deleting the rad3 or the rad 1 or the rad2 or ...  We don't know your intention. And yes - post a dwg and tell us what you need.
cadder
Jürgen Palme
No aplicable
I figured out a solution on my own. All I had to do was trim the right end of the arc. Thanks for your input.
0 Me gusta
