Anuncios
trouble with my drawing transferring from model space to paper space
No aplicable
I am asking for help from anyone ever struggling with the same issue I was unsuccessful talking to a person from customer service to help. so I am completing my drawing in model space then when I am all complete I click the layout tab and nothing transfers over from model space to paper space. I have checked to make sure the layers are unfrozen and and unlocked but still it won't transfer.  please any help with this would be greatly appreciated
0 Me gusta
Responder
Soluciones aceptadas (3)
980 Vistas
4 Respuestas
Respuestas (4)
j.palmeL29YX
Solución aceptada
In the layout you must first create at least one (or more) viewport(s), e.g. using the MVIEW command.
If you already have a viewport, double click into this viewport and then do a zoom extents.
If both doesn't help post your file please.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Jürgen Palme
0 Me gusta
Moshe-A
Solución aceptada
@Anonymous ,
when you switch to layout, a viewport is added to you paper space. it's like a telescope to your model space. double click inside viewport and do a zoom all - now you will see your drawing but this is not enough cause you now have to determines your viewport scale and that's depend on your drawing units?
Moshe
0 Me gusta
No aplicable
it happens with all my files and neither of those worked I tried that before as well
0 Me gusta
BeKirra
Solución aceptada
Also have a look "vports" command in HELP.
Then having some practice you'll be fine.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 Me gusta
