Trimming a block array
Hi all,
I have made a dynamic block for a crosswalk set up so that I can place it and then pull it to a specified length using the array dynamic command. I need to be able to have the crosswalk trimmed to the sidewalks its connecting. I know you can do it the old fashion way of exploding it and then trimming it and I've tried using a xcut but it cant trim to arcs. any help would be appreciated.
-Devin
nikm42Q9N
you need to put a stretch dynamic on the dynamic block. that way the pcs are adjustable
Alfred.NESWADBA
if you have a closed polyline as border you might use command _XCLIP (>>>details<<<)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
If I use that command I cannot trim the walk to the curved sidewalk. the polyline boundary can only be straight line segments. Any other ideas? Thanks.
Alfred.NESWADBA
Correct, in case it does not depend on 100% accuracy (as sidwalks are not really build with curves, but segmented lines) ... I would:
  • draw a SPLINE as border
  • use command _SPLINEDIT ==> convert to polyline ==> precision set to 10
  • use this new polyline, which is quite close to curved (shown in attached dwg-file).
For now I do not have an idea for real curves using that option.
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
command _CLIPIT could be an alternative too (but also does some segmentation).
- alfred -
Alfred NESWADBA
I'll see what I can do with that, thanks!
