Trim tool won’t work
jordy548
jordy548
For a few days, trim tool has been behaving unusually. It doesn't trim anymore and I'm relying in deleting things I don't want to because trim tool won't work. It will select an object but it won't trim and even if I press delete, nothing deletes unless I remove trim mode and just generally delete. I've tried restarting Autocad, changing Trim mode to from quick mode to standard, changing the value to 0 and nothing has changed. It's very frustrating and I can't seem to find any solutions online on how to fix this. I used to be able to use trim tool so easily.
pendean
Community Legend
Community Legend
Does this occur in ALL of your files, or just this one?
What changed with your setup or PC in the last few days?
DO you have a 3rd add-on installed?
Your exact version of AutoCAD as listed inside the program using ABOUT command is...?
And your OS is...?
jordy548
I think I just solved it. I’ve been told that trim tool should be on standard mode, but I changed it to quick mode to see if it would work, and it seems to allow me to trim the way I want/the way I was used to.
