Anuncios
Trim out open areas from a double cut operation
No aplicable
I have an operation where I double cut a part. Once cut you should be able to see through the part where the contour edges are. I tried to use trim surface and I can not figure out how to delete the areas where there should be no extrude. Please help
0 Me gusta
Responder
325 Vistas
6 Respuestas
Respuestas (6)
j.palmeL29YX
I see you have a mix of solid and surfaces. (in the pic I moved the solid away).
I'm not sure what you want to do.
Can you show please in a sketched pic:
- where you want to cut (draw a cutline)
- what do you want to cut (the solid or the face(s)
- what do you want to delete
- and the "where there should be no extrude" I didn't understand at all.
Can you clarify please?
(a vague idea:
- use the union command to union all surfaces to one surface
- then use the slice command to to cut something.
Currently this doesn't work, but before I search what causes the failure I must understand what you want to do / to get)
Jürgen Palme
0 Me gusta
j.palmeL29YX
Do you need something like in the attached dwg?
It's not yet perfect (because of some inaccuaracies in your drawing) but if this is your goal I can show you tomorrow how you can do it.
Today in short words:
- Extrude the contour in the current XY-plane to a solid. (this is at the moment not accurate possible)
- then you can use the Intersect command to get the shown result.
Maybe you can build the model with this hints alone.
Jürgen Palme
0 Me gusta
No aplicable
This is perfect and if you can please explain in more detail tomorrow, so what I can understand how to accomplish this in the future as well as make my drawings more accurate.
0 Me gusta
j.palmeL29YX
here a more accurate solution.
HTH
Jürgen Palme
0 Me gusta
No aplicable
How did you do the second drawing? If you could explain in steps that would be helpful
0 Me gusta
j.palmeL29YX
Video
First you need a closed polyline in the XY-Plane. Neither Pedit->Join nor the Join command work without problems. (I did not yet analyse what causes the problems). Therefore I "misused" the Hatch command to create this boundary.
Then you can go two ways:
- Create an extruded Surface and use the slice command or
- create an extruded Solid and use the intersect command.
Both ways are possible, the result should be the same.
Jürgen Palme
