Trim object in dynamic array
sunyaer
sunyaer
How to trim an object ( a line) in an dynamic array?
Please refer to the files attached.
Alfred.NESWADBA
you can edit each single item, of the assiciative array, just select it using <CTRL> + <Click the item> and now you can use the grip-commands as well as the property grid to modify it.
This is different to runnig the _TRIM command itself, but _TRIM itself does not work with the associative array items, therefor you need to _EXPLODE the array (or use the upper possibilities).
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
elshawadfy
Hi @sunyaer,
 You can replace one or more items within a dynamic array.. - I believe that's what happened in your file, one of the lines was replaced with a shorter one..
1- Create any object - say a circle (or a shorter line
2- Select the array..
3- In contextual tab callled "Array" that appears go to "Options" Panel  and select "Replace Item"
   - Now select the new item (or items) you drew ( circle, line..) + enter
   - Select the base point of that object that will reside on the array path..
   - Now select the items to replace within the array..
Dwg attached..
