Trim command doesn't work on any polylines
Message 1 of 13
I am drawing using polylines in Autocad and the trim command stopped working. It doesn't come up with an error it just doesn't recognise the lines are crossing and doesn't give the option to trim. I have highlighted both lines and tried to trim. But then when I cross an elipse with a polyline I am able to trim the elipse with the polyline. But I can't trim the polyline with the elipse. It was working as normal and then it just stopped working.
Has anyone else had this problem and do you have any suggestions for fixing it?
I didn't touch any settings or anything and I have tried flattening my work in case I somehow rotated it and it has changed nothing.
Replies (12)
Message 2 of 13
Patchy
Try using different setting for EDGEMODE, it could be on different elevations.
Message 3 of 13
RobDraw
Share the file (or one exhibiting the behavior) for a definitive answer.
Rob
Message 4 of 13
pendean
Community Legend
Community Legend
>>>...doesn't recognise the lines are crossing...<<<
What is the error message at the commandline? It needs to be taller than 1-line for you to see it.
Message 5 of 13
imadHabash
would you please share with us a CAD dwg sample that describe well your issue ?
Imad Habash
Message 6 of 13
jayhar
Hello @Anonymous
Select the poly line check proprieties  Elevation is  "0"
there is an error message at the command line?????
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Revit Architecture Certified Professional
Thanks You
JAYHAR.M.J
Team Leader
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 7 of 13
This was Never a problem before 2020
Message 8 of 13
I draw two crossing ploylines and select the trim tool, I drag a box around the polylines and nothing happens I am not able to trim any of the ends???  This tool is now totally messed up.  What do you mean they have to be on the "same level" This was Never an issue with earlier versions.  Put it back the way it was!
Message 9 of 13
Kent1Cooper
@Anonymous wrote:
I draw two crossing ploylines and select the trim tool, ... I am not able to trim any of the ends???  ....
[Locked Layer?]
Kent Cooper, AIA
Message 10 of 13
Nope, just two ploylines on a blank page.
Message 11 of 13
pendean
Community Legend
Community Legend
>>>...This was Never a problem before 2020...<<<
@Anonymous then there nothing we end users can do about it: start a support ticket at your Autodesk Account page and see what else is on offer https://manage.autodesk.com/home/ (you want the ? icon to get started).
Message 12 of 13
Kent1Cooper
Are you, by any chance, working enormously far from the 0,0 origin?  People sometimes write in with various kinds of problems, and the cause turns out to be that they are at coordinate values such as 10-to-the-13th-power, meaning they're working beyond the orbit of the moon or something [I recall one involving distances multiple times the diameter of the entire solar system].
Kent Cooper, AIA
Message 13 of 13
stuart_smithXPHHB
Observer
Observer
This solved my issue.  Somehow I was working 1:1 in some far out space.  Brought it back to 0,0 and all works as it should.
