Tracking turned off?
m.barr0720181
Observer
m.barr0720181
Observer
Observer
I had to reset autocad 2020 to bring back a glitched dynamic input box. Unfortunately, the setting where you can make a point on a line, with a little 'X' has disappeared. To explain further say If I had two equidistance lines at a perpendicular angle, both joined at the end of the line to create a triangle with no hypotenuse, I would place my cursor on the opposite end of each line, to mark it and then extend each at a perpendicular angled to form a square. Hopefully someone knows the feature I am talking about and how to either get it back or turn it on again.
Max
(sorry if this is dumb I am somewhat new to autocad!)
0 Me gusta
Responder
328 Vistas
4 Respuestas
Respuestas (4)
dbroad
Polar tracking?
If you need a square or rectangle though, just use either the polygon or rectangle command.
Architect, Registered NC, VA, SC, & GA.
0 Me gusta
m.barr0720181
Observer
Observer
talking about a square was providing an example with which the feature can be used, I know about the command you just mentioned but your suggestion does not help with my question, I do not know if what I am talking about is tracking or whatever, all it does is mark a point on a line when you keep the cursor on it for a few seconds, creating a marked x on that point with which u can use extension tracking ( i think ) to create an extension from that point.
0 Me gusta
Kent1Cooper
It's Object Snap Tracking [the F11 key turns it on/off].
Kent Cooper, AIA
0 Me gusta
RobDraw
FYI, equidistant lines are parallel.
the setting where you can make a point on a line, with a little 'X'.
OSnap Tracking as mentioned above.
Rob
0 Me gusta
