Track External Reference Operations (Log File) doesn't work correctly.
LDR80
LDR80
Hello everybody!
Sorry for my english. :cara_con_una_leve_sonrisa:
My question is...
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
In the link above describe how XREF Log File (xlg) function must work when XREFCTL is set to 1.
But...
In Autocad versions newer then 2012 (wich I can test) this function doesn't work as it describe in link above.
Everytime when i do some operation whith XREF's the information about this is write in *.xlg file whith erasing existing information in this file. In *.xlg file stay information only about last operation.
In Autocad 2010 and Autocad 2012 *.xlg file contain all infomation about operations whith XREF's. Information is adding to the end of *.xlg file, not erasing existing.
Does enyone know how make it work correctly?
Thanks a lot!
Once more sorry for my english.
0 Me gusta
Responder
606 Vistas
4 Respuestas
Respuestas (4)
cheryl.buck
Autodesk Support
Autodesk Support
Hi @LDR80,
Thank you for posting your question in the Forums, no need to apologize, your post was very clear. :cara_con_una_leve_sonrisa:
I ran a test on 2017 and 2020 and am seeing that some or all of the previous content is deleted or overwritten when the file is updated.
Let me do a little research and reach out to the Product Team to see if there is an additional variable that might be affecting it. I'll plan to get back to you shortly.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @LDR80,
Thank you for posting about this issue in the forums. I was able to confirm that this is not expected behavior, so I have logged this issue with the development team for further investigation. Please do not hesitate to reply to this thread with any additional questions you may have in regard to this issue or any message that you want me to share with development that we haven’t already discussed.
You are also welcome to contact the product team directly. If you have additional comments specific to the software or its functionality for future consideration, please use the Product Feedback page. How to provide feedback on Autodesk products goes into more detail.
Another great option is to participate in the AutoCAD Customer Council. This is an opportunity for our customers to partner with the AutoCAD development team to improve future releases of AutoCAD by giving continuous feedback on ideas, designs, and early builds.
In order to get involved email autocad.beta@autodesk.com or autocad.lt.council@autodesk.com
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
LDR80
Hello, @cheryl.buck
Thank You very much for so quick answer!
It’s sad that I can put only one "Like" for your answers
With best regards from Russia!
cheryl.buck
Autodesk Support
Autodesk Support
Hi @LDR80,
:cara_sonriente: You are quite welcome! I'll keep an eye out and will post again if I see any updates on this.
All the very best and stay safe!
Cheryl Buck
