Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
ToolPalette Paths
2 REPLIES 2
443 Views, 2 Replies
ToolPalette Paths
Upgraded from autocad 2018 to 2019; I used to change the toolpalette path from one directory to another from a tool palette menu I had, the path in the "Options>Files>Tool Palettes File Locations" would change from one path to another and the palettes would change along with the path; In 2019, everytime I change to a new path it just adds the path in the "Options" making the tool palettes list to long. If I "remove all the paths except the one I want, they simply reappear and the list just keeps growing; NEED TO MAINTAIN ONLY ONE PATH AT A TIME
Tags (2)
2 REPLIES 2
john.vellek
Hi @Anonymous,
I just tried this on my side and it works normally.  I did not do a migration which is maybe the difference.
Can you try logging onto your computer a s new user and try this to see if the behavior is any different? Don't add any customization or modifications - just try adding the paths to the tool palettes. In fact, if you could record a Screencast video as you do this it would be helpful.
John Vellek
john.vellek
Hi @Anonymous,
Did you resolve this tool palette path issue? If not, Please give me some more detail so I can try to get this working normally for you.
John Vellek
AutoCAD Inside the Factory
