Anuncios
Toolpalette missing icons issue
No aplicable
I created some tool palettes on AutoCAD filled with functions from tool bars. After re-opening a programm all icons are blank. I tried to find a solution on website, but there is no spoiler suitable for me. I've also noticed that when I add any new function to a pallete all the icons appear again... It is solution, however it takes time every time I run a program again.
Could somebody help me with that issue,please?
0 Me gusta
Responder
Soluciones aceptadas (1)
1.880 Vistas
5 Respuestas
Respuestas (5)
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I am sorry that you are having problems with your Tool Palette. Is it possible to export it and attach it to a post? Which version of AutoCAD are you using?
John Vellek
0 Me gusta
No aplicable
I'm using AutoCAD 2017 with Advance Steel (however checking the Net it's probably not matter of version). Here is a part of my tools palette group. I had to change .xtp extension to any other allowed inorder to attach it here.
0 Me gusta
john.vellek
Hi @Anonymous,
I imported your palette and the images for the icons were simple white squares. I added a command (3D Array) and it placed an icon on the palette. I shut down AutoCAD and then reopened it and the icon I put on is still there.
It appears (I can't read Polish very easily - Google Translated) that the commands you added were from Advanced Steel and not AutoCAD. I am not sure where the images are stored (some DLL I am sure).
You can manually export the images for the commands in the CUI editor and then store them in a folder that is in your Search path.
John Vellek
0 Me gusta
No aplicable
Could you tell me how to do it or link me with any guide?
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
Open your Customize User Interface by typing CUI at the command line. Then select the command you have added to your palette. you will see the image at the top right. Select export and save to a known folder location. Once you have done this for each of the commands, you can then open the Tool Palette, rt-click each item and assign the exported images to the com
mand in the tool palette.
John Vellek
