Toolbars not visible - trial of AutoCAD 2026
jglombGY4A5
Message 1 of 31
jglombGY4A5
I'm working a trial of autocad2026. But I'm no stranger to autocad.
I want to add a toolbar to my screen. From the "Tools" drop down I click on "Toolbars", then select "ACAD", then select the tool bar I want to display; in this case UCS.
The menu closes, but there is no tool bar.
I tried to open a few others. MODIFY will open and docks at the right side of the screen. LAYER opens in the middle of the screen. ORBIT does not open. One of them, i don't remember which, opened out of the autocad screen. I'm running a multi screen setup, and yes I do have the up to date Nvidia driver.
Anyone have a solution?
Very frustrating. I've done this a thousand times on earlier versions and never had a problem.
Beginning to have my doubts about continuing with autocad.
@jglombGY4A5 The post title has been modified to include the product name and version - CGBenner
Replies (30)
Message 21 of 31
jglombGY4A5
You are right....sort of.
First I disabled Nvidia RTX Desktop Manager.
Then  I reset Autocad back to all defaults.
Is it perfect? Not at all. The toolbars open all crammed into the upper left corner of the screen. But I can now drag them like I should; even if they disappear when I start and reappear when they arrive at the new location AND at the same time shadows of the toolbar cascade across one of the other screens.
Oh well, I guess this is what 2 grand buys you today, mediocrity.
I really miss GenericCAD, those were the day!
Message 22 of 31
RSomppi
Glad I could help and don't forget about that ribbon.
Message 23 of 31
jglombGY4A5
You weren't any help at all.
dmfrazier was the one most connected.
@jglombGY4A5 - this post has been edited due to Community Rules & Etiquette violation.
Message 24 of 31
pendean
Community Legend
Community Legend
@jglombGY4A5 wrote:
...Oh well, I guess this is what 2 grand buys you today, mediocrity. ...
...I really miss GenericCAD...
May I ask, why do you assume AutoCAD is your only option, especially if the cost seems daunting to you (and the comparison to a less capable and cheaper software even back in the day)? Just curious, it's not 1990 anymore, choices are out there for every budget.
Message 25 of 31
jglombGY4A5
Because today 2 grand buys you nothing more than making sure autocad works with the next version of windows. Autodesk has no incentive at all to be innovative.
Those of us that were using cad in the 1990's know that innovation only came every second or third version. Which is why they went to subscription. There is nothing more that can be added to Autocad that we can not add with a LISP routine specific to our work. But "we" cannot make it it work with the next version of windows or next generation of CPU chips.
But you would think the least they could give us is a trial version that actually works.
Autocad is not the only option. I just got a refund from Draftsight after they confirmed that several of their high end 3D commands were faulty. And that's the problem; without competition Autocad has no incentive to be innovative, or even work correctly.
Message 26 of 31
TheCADnoob
TLDR: working with toolbars is going to be problematic; don't use software that you don't like (if you can get away with it); I think I found out how to tell it which monitor to use with the coordinates- see screen setting in windows
A spicy one haha, I hear you complain about having to use workarounds, but From the 2026 perspective, you're forcing yourself into the workaround. Office implemented the ribbon in 2007, and AutoCAD in 2009. AutoCAD stopped using (for out-of-the-box setups) toolbars in 2015. You will inevitably have to use a workaround to force the application to behave like it did over 10 years ago. Just because you can still get to the tool bars doent mean its going to get the care with the updates. (granted when i do the above the UCS toolbar appears for me) If you buy a modern car off the lot and require a tape deck and have problems finding a new car with one, it's not an issue with the manufacturer; it's the parameters you areusing which are out side of whats out there. (Draftsigh and Briscad both have the ribbon)
AutoCAD has done quite a bit of innovation, but you won't see it if you are using the application the same way it worked a decade ago. I say all of this understanding full well the comfort and efficiency of working with AutoCAD the way you always have, but you also inherently miss things if you are working that way. In our firm, we support our toolbar users, but there are modern commands/workflows that are not available in the toolbars. We set a rule that your preference is not worth inefficiency so in any instance where user preference runs against workflow, workflow wins out. This was not at all popular lol, but we could not work effectively if half the company could not deliver what the other half needed.
When it comes to the issues of cost, the application is either worth it to you or it's not. Don't lose sleep over a program you don't like if its not worth it. If it is worth it to use it, you have to recognize that it exists as it currently does and work with it from there. I know some firms that have switched to clones and done fine, and i know some firms that had a horrible experience with switching to a clone. At the end of the day, use the system that works for your firm/you. I know for us, we are contractually obligated to use a DWG compatible application and furthermore some of our clients specify AutoCAD DWG engine. So if you do go with a clone just make sure you know what you are contractually obligated to turn over.
All that to say, I found what i believe dictates where the toolbars go when you give them coordinates. In your screen settings on Windows, you can tell it which window is your primary. When i change this, it changes which monitor the toolbars show up on.
CADnoob
Message 27 of 31
pendean
Community Legend
Community Legend
@jglombGY4A5 wrote:
Because today 2 grand buys you nothing more than ...
...Those of us that were using cad in the 1990's...Those of us that were using cad in the 1990's
Friend, most of us replying to you have used AutoCAD since the 1980s in DOS, we've done it all and see it all. And we all use AutoCAD without workarounds (but not the ancient ways you are trying to use) decades ago now.
Here is something you seem to either not know, or have chosen to ignore: your AutoCAD subscription price includes ALL of these variants for free as well, you are literally paying for the whole set, not just one application
  1. AutoCAD (plain)
  2. AutoCADARCHITECTURE
  3. AutoCADMEP
  4. AutoCADMECHANICAL
  5. AutoCADMAP3D
  6. AutoCADELECTRICAL
  7. AutoCADPLANT3D
  8. and everyone's favorite and very old 1990s add-on RASTER DESIGN.
So, your 2grand is buying access to all of that. But none of them use 1990s toolbars or those old ways anymore.
Glad you tried something else, but you stopped after using the least popular alternative, not the most popular one. PLUS all the others out there.
Message 28 of 31
dmfrazier
"...we all use AutoCAD without workarounds..."
Plenty of us use workarounds.
"...you are literally paying for the whole set, not just one application"
This is a pretty good description of what many see as "the problem."
Message 29 of 31
RSomppi
That's quite rude to say to someone giving you good advice. Just because you chose not to take it doesn't mean you can attack the source. If you actually headed the advice, you could have gotten past this already.
You should have just walked away from AutoCAD like you wanted to in the beginning because it seems like you are going to.
@RSomppi - moderation team has edited quoted material
Message 30 of 31
jskalaXDDX5
A Brand Ambassador and a Clairvoyant walk into a bar.  The bartender yawns.
Message 31 of 31
RSomppi
That's no way to treat customers. Bartender doesn't know a good thing when it's right in front of him. It's funny that you aren't saying anything about the people who are literally bashing you for not embracing today's tech.
