Toolbars are missing
bustr
Message 1 of 16
bustr
@bustr - the title of this post has been edited due to Community Rules & Etiquette violation.
One slip of the cursor and I see this drafting and annotation ribbon. All of my toolbars are gone. How do I restore the workspace I worked so hard to build?
Replies (15)
Message 2 of 16
Valentin_CAD
@bustr ,
Consider the suggestion from this link:
@bustr wrote:
... How do I restore the workspace I worked so hard to build?
May want to read these also:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 16
bustr
If autocad can screw this up in one click shouldn't there be a way to fix it with one click?
Message 4 of 16
bustr
@bustr - this reply has been edited due to Community Rules & Etiquette violation.
Thanks. This doesn't help though. If autocad can mess things up with one click then they need to come up with a fix that doesn't involve the user doing any research.
Message 5 of 16
cadffm
Nobody knows WHAT you customised, nobody know where(how) you customised
so nobosy know what you expectd.
>>" How do I restore the workspace I worked so hard to build?"
If you worked a lot on this, you should had to learn more about the workspaces, profiles & cuix files,
what include import/export and so - backup & restore.
Yes, it is possible to change all this back, but not in each case.
 - Are you talking about Workspace, perhaps the only one you have to do is: Set your wanted Workspace current,
if you saved this one..
Are you talking about editing standard-cuix files (rarely a good idea)  ?
- Start CUI command again, rightClick on the m,ain cuix (if you are talking about), RESTORE
Sebastian
Message 6 of 16
bustr
This is what I want to see in autocad, not some ribbon.
Message 7 of 16
bustr
Apparently it was an accidental click on this that caused the problem though it has happened several times when I was typing. I can't see undo the damage other than a lot of time consuming clicks to re-open and rearrange the toolbars. I should not have to do this.
Message 8 of 16
j.palmeL29YX
After you have "worked so hard to build" a workspace I hope you saved it:
Later you can restore this workspace each time you need it by selcting it from the list above.
Jürgen Palme
Message 9 of 16
bustr
Yes. I did. I can't see a way to restore it.
Message 10 of 16
cadffm
>>". I should not have to do this."
It is your fail if you changed the current temporary workspaces without to save them.
You should: Work with named workspaces
1. After you edited the workspace, save it, Command: WSSAVE
2. If the main cuix is the standard cuix (acad.cuix),
    you should Export/Save this .cuix as well (this is where the named cuix stored)
Time to time you should EXPORT all stuff (this incl. also the acad.cuix and is the best way to save near to all program stuff)
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-5EDF557F-098A-4F81-8104-3F0890B5CCC2
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-51E1D144-1EC4-4B4B-B4FA-F8456D40A4AF
Sebastian
Message 11 of 16
cadffm
Did you overwrite the original "Drafting&..." workspace, or did you used your own Workspace(name)?
See my Reply above..
You can try to restore the main cuix, start command CUI and... as I wrote above.
Sebastian
Message 12 of 16
bustr
With all of the useless changes that autocad has made over the past two decades did it never occur to them to have a "RESTORE PREVIOUS WORKSPACE" option?
Message 13 of 16
Valentin_CAD
@bustr ,
Should only take you a few minutes.
Right click on an empty space (Yellow arrow/circle) then in AutoCAD, select your desired options.
Then save your workspace and consider saving it as a Profile.
Emilio Valentin
Message 14 of 16
cadffm
>>" did it never occur to them to have a "RESTORE PREVIOUS WORKSPACE" option? "
How am I supposed to know? You have to ask the manufacturer about that.
BTW: I think that even if the function would be added,
it wouldn't help you - because this function would only only try to set "the last name Workspace" current,
but if the workspace is missing..
Sebastian
Message 15 of 16
pendean
Community Legend
Community Legend
Message 16 of 16
RobDraw
The responsibility is all on you. If you are going to create a customized workspace, YOU need to know how to save it and restore it. AutoCAD can't read you mind.
Rob
