Anuncios
Tool Pallet import
trusty110
Tool Pallet import
trusty110
i have a drawing (.dwg) created on an old pc with AutoCad 2005.  Can I open it with 2025 and import the old Tool layout pallet menu?
0 Me gusta
Responder
381 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
DWG files do not store Tool palette (TP) information to "import" from, but you can create a new TP in AutoCAD2025 from it's block content for sure using ADCENTER command for example, or manually drag-and-drop to a new TP as well. Give each a try.
0 Me gusta
trusty110
thanks much. are you saying that there is a file created in the 2005
version with the extension '.tp' that may be imported to the 2025 version?
ie, I can open the drawing in 2025 version, then imported the old tool
template?? thanks again.
0 Me gusta
trusty110
if you think it's too good to be true (or too easy)... you're right.
0 Me gusta
