Tool Palette Icon "Command Tool.....PNG"
mikeevans6697
mikeevans6697
AS a result of another conversation on Tool Palette Speed (http://forums.autodesk.com/t5/autocad-civil-3d-general/tool-palette-block-insertion-delay/td-p/62119... I am modifying our tool palettes to use Macros for block insertion. The issue I have is the icons. I have placed all of my PNG Format icons on the folder ..TOOLPALETTES/PALETTES/IMAGES.
For each tool, I right click, select specify image and select the appropriate PNG file. When I close autocad and re-open. It recreases all of the icons with names such as Command tool_2C28463D-1CF2-4308-848F-31A2743B9321.png and assocaites this file with the tool on the palette. Why are these duplicate files being created and the original files not keeping there assocaition with the tool?
john.vellek
Hi @mikeevans6697
Working with Tool Palettes can be tricky at times. I personally have seen the same thing when creating custom palettes. The issue arises I think, when the images are not placed in the same location as the ATC file. Luckily, the duplicate files are tiny.  I have attached an AKN Article About Sharing Tool Palettes and Tool Palette Groups which might apply in some fashion to your issue.
When I create a new palette in 2017, add a block, and then look at the image properties it shows me that I have two images associated with the icon - one for light backgrounds and one for dark. When I open the default location for the images I see that additional PNG files are created. This is normal.
Are you unable to use the new palettes and the new icons?
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Good morning mikeevans6697,
I am checking back with you to see if my post helped you at all with your Tool Palette question. Please let me know so I can put this to rest or continue to assist you. Your response will also help other forum users.
John Vellek
mikeevans6697
Thanks John. The tools work fine, I was just trying to clean up the directories and noticed the extra icons.
