Toggling Lights
Test.1.01.cer.2002
Toggling Lights
Test.1.01.cer.2002
Other than by changing the view style, is there any other way to universally toggle all lights on/off in AutoCAD 2017? If there isn't, is there a plugin that will allow this?
Thank you to anyone who can help,
Charles Reedy
0 Me gusta
Responder
Soluciones aceptadas (1)
1.002 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
Solución aceptada
this should be differentiated between lights as object with position and contrary to that sun-light and sky.
I don't know a way of turning off all 3 types with one step (without development).
If it's just the lights (point, spot, distant, weblight) you can open the "lights in model" dialog, select your lights in that dialog and then turn them on/off in the properties window.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
Test.1.01.cer.2002
This worked, sorry for the untimely response.
0 Me gusta
