this should be differentiated between lights as object with position and contrary to that sun-light and sky.
I don't know a way of turning off all 3 types with one step (without development).
If it's just the lights (point, spot, distant, weblight) you can open the "lights in model" dialog, select your lights in that dialog and then turn them on/off in the properties window.
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
