*.tmp File Question
dany_rochefort
*.tmp File Question
dany_rochefort
Hi guys,  my autosaves are in 5 minute intervals.  Although my autosaves do generate a *.tmp file every 5 minutes, the files remain in *.tmp format and it takes 3-4 hours for one of them to be converted into *.sv$ that i can actually use to recuperate my work.
Can someone please advise ? Thank you
0 Me gusta
Responder
Soluciones aceptadas (2)
584 Vistas
4 Respuestas
Respuestas (4)
RobDraw
Solución aceptada
Those formats are generated separately. Autosaves are deleted automatically by default. Does that help explain it?
Most people change the extension to .dwg to make them usable.
Rob
0 Me gusta
dany_rochefort
Hi Rob, i was under the impression that my *.tmp files were eventually converted into *.sv$. So yes that does answer the question. Thanks
This leads me to my next question: If autosaves are deleted automcatically, how can i make use of them? Is autocad simply keeping my most recent autosave while deleting the old ones ?
Any thoughts ?
0 Me gusta
owen66
Solución aceptada
One of the commonly misunderstood things about AutoSave: it's not meant as a record, it's meant as a last resort solution when AutoCAD crashes, is forced close or otherwise does not close cleanly.
If ACAD closes clean, it wipes the AutoSaves as part of its cleanup.
Best habit is to get into CTRL+S often and especially after a significant edit.
"Aah, there's nothing more exciting than science. You get all the fun of sitting still, being quiet, writing down numbers, paying attention...science has it all."
dany_rochefort
@owen66
Thank you for that clarification.  I did not know that !
