Titleblock attributes not appearing
nicholas.santorso2
nicholas.santorso2
I have a block that has attributes of which are not showing in a particular drawing, although they do show in other drawings. You'll see from the snip what attribute should be showing in the title block. NOTE: I have entered some information and it still doesn't show
Battman- Invisible is off. All attributes are ON. Layer is ON.
Why would this template work in one drawing but not the other?
I've attached the drawing.
Replies (28)
cadffm
'already attached' -  I know that since 10.Jan, thx
What about my font question?  CLICK
Sebastian
nicholas.santorso2
The title block is a block that's entered, not an xref.
nicholas.santorso2
I do have Romans in my drawing... no value comes up when i enter FONTAL
nicholas.santorso2
This did not work either.
cadffm
But I asked about what is used in the drawing: Romans9.shx!
Set Fontalt to SIMPLEX.SHX, run regen or re-open your .dwg and tell us what you see now.
Sebastian
paullimapa
so have you tried resetting AutoCAD yet to see if then you can install the update?
If still fails, download & install 2024 and the latest updates but don't migrate any settings from 2023 to see if the problem on this particular drawing occurs when opened up in 2024
Paul Li
IT Specialist
@The Office
nicholas.santorso2
I do have the latest update. I don't know what "Resetting" is.
paullimapa
In AutoCAD enter ABOUT command, do a screenshot and share that here so we can see what 2023 version you have installed.
To learn about Reset click on the link I provided in my previous post or as shown here below:
https://help.autodesk.com/view/fusion360/ENU/?caas=caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
But again try downloading & installing 2024 or 2025...You can still have 2023 installed and run 2024/2025 in parallel...All three 2023/2024/2025 create the same drawing format versions.
Paul Li
IT Specialist
@The Office
vinodkl
Hello @nicholas.santorso2
That's strange. Try this:
First edit the block using the "BEDIT" command. In the block editor, change one of the tag of the attribute from "REV"  to "REV_1". The attribute don't play well if there are attributes with same tag. No two attributes should have the same tag. Next save the changes in the block and close the block editor.
Type in the command "ATTSYNC", select the title block and press "Enter" key. Do you see the attribute values now?
Please find the image for reference.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
