Title block attribute
S.MANICKAVASAGAM
S.MANICKAVASAGAM
Dear Expert,
               How to batch edit in title block attribute value (like as date) for selected multiple drawing in single stroke.
         Please to be guided.
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
My body Your body Every body is Just SOIL body
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
fkp7057
Thanks To Lee-mac Lisp.
PFA Lisp which can help you in your work.
- Download this LISP file and save it in your local folder
-Give appload command in AutoCAD
- Select download lisp file " BAtteV1-4.lsp" from your local folder
- Give command " battle" this will open dialog box as shown below image.
1. Here you have to give Block name. in your case it should be your title block name.
2. Here you need to put attributes name.
3. add attribute value here.
4. Click on add item, this will add this particular block attribute in list.
5. after adding multiple attribute you can save as  file, or latter you can use by loading button (6).
or...
7. you can directly select block and it attributes  by "Select Blocks..." button.
8. Then click on next
you will get this dialog box as shown in  below image, after step 8.
Here you can locate your working directory and add files where you want to do this process.
then click on Run.
RobDraw
Single stroke.
Rob
JTBWorld
Not single stroke but very easily with JTB BatchAttEdit
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
S.MANICKAVASAGAM
Dear Expert,
             I am a tekla modeler. Now, I switch over to advance steel detailing software. so, i will tried long time attempt for my customized title block setting. finally, I had achieved my fully required customized title block with attribute by your guidance. If without your guidelines I have been done can't possible this one. so. lot of thanks for you.  🙏🙏🙏
Thanks & Regards
S.MANICKAVASAGAM
FAB. DETAILER
