This text override is looking like a code can anyone explain what it is.
pankaj
pankaj
Hello Guys,
I am having a query about the text override issue i noticed it when i was working with my Japanese clients.
Anyone Please explain why this code is getting reflected in Rotated dimension override property.
like
<>{\fMS Gothic|b0|i0|c128|p49;\X{\fMS Gothic|b0|i0|c128|p49;(}6{\fMS Gothic|b0|i0|c128|p49;リフト)}}
Instead of
<>\X(6リフト)
I am attaching the picture and drawing file for your more reference.
Thanks in advance,
Pankaj
Valentin_CAD
@pankaj ,
Apart from using "Character Set".
Override Dimension Text
The dimension value that is displayed can be replaced using the DimensionText property. Using this property you can completely replace the displayed value of the dimension, or you can append text to the value. To represent the measured value in the override dimension text, use the character string “<>” in the text.
Paragraph texts in AutoCAD can contain control codes which influence appearance of the text. These formatting control codes are automatically inserted in the internal MText editor. But if you edit your texts with an alternative editor (e.g. Notepad), or if you generate them programmatically, you can use these codes to format your paragraph texts.
Code Function
\LStart underline
\lStop underline
\OStart overstrike
\oStop overstrike
\KStart strike-through
\kStop strike-through
\NNew column
\PNew paragraph (new line)
\pi \pxi \pxtControl codes for bullets, numbered paragraphs, tab stops and columns - e.g. bullets: \pxi-3,l3,t3;, tab stops: \pxt10,t12;
\XParagraph wrap on the dimension line (only in dimensions)
\QSlanting (obliquing) text by angle - e.g. \Q30;
\HText height - e.g. \H3x;
\WText width - e.g. \W0.8x;
\FFont selection
  • e.g. \Fgdt;o - GDT-tolerance
  • e.g. \Fkroeger|b0|i0|c238|p10 - font Kroeger, non-bold, non-italic, codepage 238, pitch 10
\SStacking, fractions
  • e.g. \SA^B:
    A
    B
  • e.g. \SX/Y:
    X
    Y
  • e.g. \S1#4:
    ¼
\AAlignment
  • \A0; = bottom
  • \A1; = center
  • \A2; = top
\CColor change
  • \C1; = red
  • \C2; = yellow
  • \C3; = green
  • \C4; = cyan
  • \C5; = blue
  • \C6; = magenta
  • \C7; = white
\TTracking, char.spacing - e.g. \T2;
\~Non-wrapping space, hard space
{}Braces - define the text area influenced by the code
\Escape character - e.g. \\ = "\", \{ = "{"
Codes and braces can be nested up to 8 levels deep. Formatting codes can be removed via the context menu in the MText editor.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
