The TRIM command has the cut line beyond the frame
baykakabay
baykakabay
Video The trim command works incorrect when I want to trim multiple lines. But when I trim 1 object, it trims correct. UCS is not too far (can see in video)
0 Me gusta
Responder
Soluciones aceptadas (1)
1.168 Vistas
12 Respuestas
Respuestas (12)
Patchy
Attach your .dwg
0 Me gusta
baykakabay
I delete that file. But this file has problem with trim too
0 Me gusta
Patchy
Because it's millions miles away from 0,0,0.
0 Me gusta
baykakabay
I relocated my usc closer, but the problem still remained
0 Me gusta
Patchy
Solución aceptada
It works for me.
You don't move the UCS, look at the locations of your lines.
use Move, select everything and click on one of the line, type in 0,0,0
It will work.
0 Me gusta
pendean
Community Legend
Community Legend
Your video is too fuzzy, not very clean: try a better recording option, like this freebie https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
It looks like you are not able to complete a selection with FENCE perhaps? Who knows.
0 Me gusta
pendean
Community Legend
Community Legend
I can't repeat the problem in your posted file.
0 Me gusta
pendean
Community Legend
Community Legend
@Patchy means this (see attached)
0 Me gusta
Patchy
This is what happened
Select all lines to trim and when selected it skipped and not using the nearest line as a cutting edge.
0 Me gusta
Kent1Cooper
How far away?  If the drawing unit is a millimeter, approximately 9 times the distance from the Sun to the Earth.  That kind of distance can cause many problems, because AutoCAD can work with only 16 significant figures.  I would look into your drawing template files, to see whether they are the source of things being so far away from the origin.
Kent Cooper, AIA
0 Me gusta
Patchy
Mars coordinates?
0 Me gusta
Kent1Cooper
@Patchy wrote:
Mars coordinates?
More like Saturn coordinates.  It's about 9-1/2 times as far from the Sun as we are, so only slightly beyond those locations in the drawing.  Mars is much too neighborly -- a mere [roughly] 1-1/2 times as far.
Kent Cooper, AIA
0 Me gusta
