The Object is Invisible, Must click to see it :(
No aplicable
Hay, My Name is Adi.
I am a new member here, nice to meet you all :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
I just trying to learn AUTOCAD 2015
This is my first time to use it.
I decided to search tutorial on the internet, and i got one.
when i do excercise...
make a Rectangular
i set the size and press enter.
The object that i make is not visible.
I must move over the cursor to be able to see it.
and click it.
Compare to the tutorial...
My workspace is different, i didn't see the grid... and the X Y point is turn grey.
I Attach the image.
Please, If anyone can help me... i really want to learn this, but get stuck on the first place.
And.. i am sorry for my bad English.
Thank You before :cara_con_una_leve_sonrisa:
0 Me gusta
Responder
3.671 Vistas
8 Respuestas
Respuestas (8)
nestly2
Welcome to the Autodesk Forums.
I believe you may be zoomed in too close to see your object (and the Grid)
Roll the mouse wheel backward until the grid becomes visible.
or
Doubleclick the wheel button (middle button)
or
Zoom <enter> 1 <enter>
No aplicable
Thank You for the Reply, Sir... :cara_con_una_leve_sonrisa:
I tried your solution..
but...
It still not working..
When i try to draw a line.
i just see 2 dot.
if want to see the line.. i must move over my cursor.
And.. the same when I try to open the Tempelate...
I just see the dot only...
I attach the new Image from my screen
The X and Y also become dot... you can see the picture.
0 Me gusta
Ajilal.Vijayan
By any chance did you change the default color for the elements in here ?
If yes, try to restore that. (Click the +' sign to show the image)
Spoiler
No aplicable
Thank You again for the Reply Sir... :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
I am very happy that many people here want to help me..
I try your solution, Sir..
But...
It still can not help me with the problem...
but then.... in the "TOP LEFT" of work area...
I found it !!! "THE VISUAL STYLE" !!
That's it!!
Finally !!!
I change it from "2D Wireframe into Conceptual"
And.... I got the Grid !! I Got the X and Y, red and green. And I got the Line !!
Waaaaa!!! I don't know... but i am very happy now... :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
"Problem Solved"
But still, I Thank You Very Much for the Help. Thank You All,
Thank You Mr. Nestly2
Thank You Mr. Ajilal.Vijayan
and Thank You for Autodesk... for this Amazing and Helpful Forum :cara_con_una_leve_sonrisa:
I Attach The Image
Ajilal.Vijayan
Hi Adi,
Its good that you solved it.
But your drawing seems to be a 2d drawing, so you should use 2D wireframe visual style for the display.
bl4ck_aca wrote:.
When you switch the display it actually use a different context settings from here (see the image)
Select 2D model space and Click 'Restore current Context' to see if this helps.
Spoiler
No aplicable
Yes, Sir Ajilal.Vijayan...
"maybe" i found the solution..
but... i think you are right... my solution is not a solution...
Yes, will working on 2D Drawing in the future.
But... As i mention before.. when i choose "2D Wireframe" X & Y, The Grid and the Object I draw become "a dot" only dot no line.
I try to reset Autocad to their default.. it's not working
I try to Uninstall and Install again... it's not working
I try to do as you said, Option -> Display Tab-> Colors-> 2D Model Space-> Restore Current Context
and... it's not working too...
Oh my God...
I don't know what happen... :cara_de_decepción:
Maybe....
Something wrong with the software...
Something wrong with my computer...
Hem... I will try to install Prev Version of Autocad... Maybe Autocad 2013
0 Me gusta
No aplicable
Hi
I don't know if my answer can help you after all this time
but a few days ago i faced the same problem with AutoCAD 2016
and i found this solution :
1- open AutoCAD
2- Option > System > Graphics performance > Toggle the hardware acceleration on and off to see what gives you the best performance
No aplicable
Totally forgot to check this setup on my new computer, thank you.
0 Me gusta
