The current layer switch automatically to other layer
Message 1 of 9
Why the current layer switch automatically to other layer when I draw a line?
Replies (8)
Message 2 of 9
imadHabash
does this happend in a certain drawing or it's happened i every CAD drawing ? you may have some outsource plug-in or lisp that make this weird behavior .
Imad Habash
Message 3 of 9
Alfred.NESWADBA
How do you start the line command? From toolbar, from an own customized menu, any tools loaded which catch commands?
Can you please try this:
  • Make sure layer 0 is on, thawed and current
  • start command _.LINE 0,0 10,10 (including point and underscore)
  • end the command with <ENTER>
...which layer is now current?
...which layer does the line now have?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 9
pendean
Community Legend
Community Legend
AutoCAD2017 is not new: so this just started? or did you all buy an add-on recently?
Ask anyone else in your office about it?
Message 5 of 9
Dear alfred,
I set  a layer for me draw a line, when I draw a line, it automatically change the layer to wall layer.
Message 6 of 9
j.palmeL29YX
And what about "How do you start the line command" ?
Jürgen Palme
Message 7 of 9
TheCADnoob
how are you setting your layer?
CADnoob
Message 8 of 9
Dear
Message 9 of 9
Kent1Cooper
@Anonymous wrote:
So you're not  drawing a Line, after all.  PL is [by default] the command alias for the PLINE command, which would simply start a Polyline [on the current Layer], and a Polyline is a different entity type than a Line.
It sounds like you have a custom definition of a command named PL that is not  just the PLINE command called by the default PL command alias.  Do you have an acaddoc.lsp file that contains  (defun C:PL ...  in it?  If you're not sure, put  (findfile "acaddoc.lsp")  in at the command line, and if that returns something other than nil, it will tell you where it is -- open that file and look for a command definition.
If you force it to use AutoCAD's basic command, by typing .PLINE [with  the preceding period/decimal], does it do the same thing?  If it works normally without changing the Layer, then you do  have a custom-defined PL command that is changing the Layer.
Kent Cooper, AIA
