The correct line thickness is not shown (not a problem with the show thickness)
m_scavo
m_scavo
Hello, I kindly ask for help with an Autocad problem. I kindly ask for the solution of a problem. In my file when I put line thickness it makes my lines all the same even though I have show thickness enabled. In fact if I change layer the colors are different but the thickness remains the same even though I have changed it. I repeat the show line thickness option is active. I am willing to send the file. Thank you and hope for an answer
m_scavo
Fixed, in the upper right corner you have to set the thickness as a layer, like the colors.
