Texture map "Sample size" units do not match system units.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi. This is something that happens both in 2016 and 2017 versions of AutoCAD. It did not happened in v2015.
Seems that the texture map sample size has to be entered ALWAYS in mm, independently of the drawing units. That makes constructing and editing materials quite annoying.
In order to reproduce the problem:
1.- Set drawing units in meters
2.- Make a 1 meter x 1 meter 3DFACE
3.- Create a generic material with an image
4.- Set image size 1x1 and apply material.
The result is as follows:
As you can see, the material mapped on the 3dface is completely purple, since this is the colour of the botom left pixel of the texture image. The material sample also shows lots of small repetitions on its geometry > It seems that Autocad is considering that the image size is 1mm x 1 mm.
It has ignored the system units.
5.- Now set Sample size to 1000x1000 The result is.....
It confirms the bug. In order to an image to appear 1 time in a 1mx1m face, the sample size has to be set to 1000x1000 . As a confirmation test, you can write in the sample size box "1 m" and it inmediately gets converted to 1000.8 (it is not even precise enough with the conversion... 1000.8?)
6.- Now set the units to inches.... nothing changes in the material.
In AutoCad 12015 a change in the system units automatically changed values in the Image sample size. Now it just ignores it, so the user is forced either to work in milimeters or face continuous problems derived from this behavior.
Can anyone confirm this bug or give a solution for the problem?
Thanks in advance.
Luis
